forced hot water boiler town increased water pressure
gage123
gage123 Member Posts: 3
the town increased my water pressure now my shower hot water only lasts for a minute and then gets colder. what do i adjust?
    Jamie Hall Member Posts: 27,393
    How is your hot water made and stored? Indirect? Stand alone? Tankless?
  • gage123
    tankless , forced hot water. coil setup on the side. wel mclain
  • STEVEusaPA
    PRV on your incoming supply. You may need other components, depending on plumbing and local codes.
    Zman
  • gage123
    I have a ball valve on the same line going in ,adjusting that will that do it or does it need the pressure reducer?
    You need the pressure reducer -- a ball valve isn't the same thing at all. Leave that wide open.
    hot_rod Member Posts: 27,492
    Probably a thermal expansion tank also, they may have added a backflow device.
    Put a gauge on a hose bib to see what pressure they are sending you. 55- 60 psi is adequate. Code suggests 20 -80 psi max.
    Above 80 psi you may have issues with faucets, toilet ballcocks, etc.
  • bburd
    bburd Member Posts: 1,305
    The problem might be attacked more easily and at lower cost by installing a low flow showerhead, if you don’t already have one.
    Bburd
    MaxMercy
