What kind of circulator is this?
Huuyz11
Huuyz11 Member Posts: 4
Looking the replace the circulator that feeds my Smart40 indirect, it's been making noise, very hot, slow hot water, I think because the aquastat on the tank died and it's been running 24/7 for a good year now. I've never seen this kind before with the holes, no taco label.
Wondering if I can replace this with a 007-F5 or if I need something bigger because it's and indirect, and if I need IFC on an indirect. My other 2 zones in the house are being feed by 007-F5.
Thanks
  • Ironman
    Ironman Member Posts: 7,899
    It looks like a 007.
    Bob Boan
    EBEBRATT-Ed Member Posts: 20,063
    An 007 shoul be fine you usually need about 7 gpm with an indirect
    STEVEusaPA
  • SteveSan
    SteveSan Member Posts: 298
    I just checked with engineering and that is an older 007-IFC pump that is no longer available. If it doesn't require the IFC you can go with a standard 007-F5.
    Huuyz11
  • Huuyz11
    Thanks guys. I'll purchase the 007 ifc. Appreciate the help, going to replace this and the aquastat before it gets worse now that winter is over.
    SteveSan
