indirect storage tank
DaveM
Member Posts: 77
I'm going to be installing a superstor storage tank on a oil fired hydronic boiler. is it ok to puncture the tankless coil and plug the tapping's on the face plate?
He means the old tankless coil on the boiler, and making the new indirect on it's own zone.MaxMercy said:
Doesn't your storage tank require a working tankless coil?DaveM said:I'm going to be installing a superstor storage tank on a oil fired hydronic boiler. is it ok to puncture the tankless coil and plug the tapping's on the face plate?
no not at all the indirect storage tank is a replacement for the small tankless on the boiler0
jamie if I leave an open end and in the future the coil rots out the boiler water will leak all over0
thanks Steve i thought that was understood0
Steve do you think its ok to puncture the old coil before capping it off instead of putting a new blank face plate on0
Well, that's true. However, if the coil isn't already leaking -- which you would know -- the odds of it doing so at some future time are slim to none. Just arrange it so the open end is low, so it can't accumulate wate.DaveM said:jamie if I leave an open end and in the future the coil rots out the boiler water will leak all over
Or you could take it out and put a blank face plate on -- if, that is, you can get it out. Most often, you'll break at least one of the studs holding it on. Or you could puncture it somehow inside the boiler and put caps on both ends. Or...
Myself I'd not make the job any harder than it had to be, But maybe that's just me.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England3 -
Yeah, I brain farted because I was just thinking about using a standard electric water heater as storage from the coil.STEVEusaPA said:
With no flow it isn't going to rot out from the potable water side. If copper in an iron boiler rots out from the inside, you have bigger problems.0
the relief valve is a good idea but if i puncture the coil letting it fill with boiler water and cap off both hot and cold there's no chance off pressure build up. what do you think0
If you leave the coil intact and don't puncture it do not plug it it will build up air pressure. If you puncture it then cap both tappings obviously.
Most just disconnect and leave un capped which is what I would do.
The choice is yours0 -
I have completed this project for several customers. Disconnect the potable water piping and leave the coil uncapped. If it starts to leak in the future you can address it at that time. Your idea is sound but ask me how many good intentions, that were unnecessary at the time, and were the cause of a real nightmare. I wish I left that alone at the time of my great idea.
3
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
