Blowdown With King Valves?
cross_skier
Member Posts: 201
@DanHolohan says 10psi blowdowns will extend the life of boilers and @New England SteamWorks does them. Yet king valves are rarely installed. Any idea why?
Does anyone have a video of a 10psi blowdown of a residential boiler?
Thanks
https://youtu.be/L11ywcjSOFA
Thanks
https://youtu.be/L11ywcjSOFA 1
Why? King valves aren't cheap. They have to be full port ball type valves. Priced them out lately?Br. Jamie, osb
Maybe $60 to $100 for valves. Seems cheap if they are effective at flushing the muck out of a boiler and extending the life a boiler a few years@DanHolohan says gate valves or butterfly valves are appropriate for king valves. I watched @ethicalpaul 's video and he chose ball valves for his risers. Would ball valves be ok?0
Or rising stem gates in the larger sizes. $$$$Jamie Hall said:Why? King valves aren't cheap. They have to be full port ball type valves. Priced them out lately?
Full port, steam rated ball valves are fine. Don't forget you need to isolate the return as well.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
My ball valves are getting stiff. This may be a a downfall of all valves...exercise them every season.
Every steam job should have Dan's set up to remove the mud in the mud leg. A gate valve on the discharge (king valve) and a or butterfly or ball valve for the blow down is not that expensive when compared to the cost of a premature boiler failure. I always preferred USA valves to the foreign junk since the USA valves always lasted much longer.1
Yes, exercise your valves at least every year, that includes you Paul.
Most of the King valves I have seen are from the 30's & 50's.
Almost always 10-12' off the floor.
3-5" flanged gates that have not been touched since installation by dead men.
A couple have leaking flanges.
Might just remove them and insert the short piece with flanges instead.
There is a term for that double flanged nipple, can anyone tell me?
I figure I will not even try...might get them closed and not reopened.
Have some 2" ball valves for Kings above steam boilers that are only 20 years old.
Got 1 out of 4 to move.2 -
Thanks, any experience with Nibco T-111's? They are rising stem gate, probably American made
. 0 -
@cross_skier
The Nibcos are rated 125 psi steam. Cheap valve but ok.
@Jamie Hall Nipple with 2 flanges =spool piece
Not all ball valves are steam rated.
I always like Apollos...probably more $$$$$ than most
They even make Carbon Steel ball valves like the Apollo 89-100 with options for 250 # steam
I would be almost certain those Nibco's are made in China not that it matters1 -
Just do the blowdown annually and they'll be fine.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
Just to be sure I picked up two Apollo 2" forged carbon steel ball valves for a nice price. Those are critical valves. I'll dump the Nibcos on eBay
Thanks
I open and close my king valves yearly but have never used them.
I wash everything out with a wand.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I have done 2 blowdowns on mine since 2014, with my water treatment it just doesn't get that dirty. The blowdown is....entertaining. It does blast the water out for sure.0
- 50 Industry Classes
