Blowdown With King Valves?
@DanHolohan says 10psi blowdowns will extend the life of boilers and @New England SteamWorks does them.  Yet king valves are rarely installed.  Any idea why?
Does anyone have a video of a 10psi blowdown of a residential boiler?
https://youtu.be/L11ywcjSOFA
ranzerox
    Jamie Hall Member Posts: 27,584
    Why? King valves aren't cheap. They have to be full port ball type valves. Priced them out lately?
  • cross_skier
    cross_skier Member Posts: 201
    Maybe $60 to $100 for valves.  Seems cheap if they are effective at flushing the muck out of a boiler and extending the life a boiler a few years
    @DanHolohan says gate valves or butterfly valves are appropriate for king valves.  I watched @ethicalpaul 's video and he chose ball valves for his risers.  Would ball valves be ok?
  • delcrossv
    delcrossv Member Posts: 2,204
    edited January 2022
    Or rising stem gates in the larger sizes. $$$$
    Full port, steam rated ball valves are fine. Don't forget you need to isolate the return as well.
  • cross_skier
    I brought a pair of 2" Nibco T-111 rising stem valves for a $50/shipped.  That's not a lot.  I think they will be suitable.  They were new old stock.
    Yes, I'll be using a 1-1/2" ball valve to isolate the return.
    delcrossv
    ethicalpaul Member Posts: 8,933
    My ball valves are getting stiff. This may be a a downfall of all valves...exercise them every season.
    delcrossvcross_skier
  • retiredguy
    retiredguy Member Posts: 1,101
    edited January 2022
    Every steam job should have Dan's set up to remove the mud in the mud leg. A gate valve on the discharge (king valve) and a or butterfly or ball valve for the blow down is not that expensive when compared to the cost of a premature boiler failure. I always preferred USA valves to the foreign junk since the USA valves always lasted much longer.
    cross_skier
  • Motorapido
    Motorapido Member Posts: 314
    You better go see the doctor for that symptom.
    ethicalpaulJUGHNE
  • JUGHNE
    JUGHNE Member Posts: 11,604
    Yes, exercise your valves at least every year, that includes you Paul.
    Most of the King valves I have seen are from the 30's & 50's.
    Almost always 10-12' off the floor.
    3-5" flanged gates that have not been touched since installation by dead men.
    A couple have leaking flanges.
    Might just remove them and insert the short piece with flanges instead.
    There is a term for that double flanged nipple, can anyone tell me?
    I figure I will not even try...might get them closed and not reopened.
    Have some 2" ball valves for Kings above steam boilers that are only 20 years old.
    Got 1 out of 4 to move.
    cross_skierethicalpaul
  • cross_skier
    Thanks, any experience with Nibco T-111's? They are rising stem gate, probably American made.
    EBEBRATT-Ed Member Posts: 20,485
    @cross_skier
    The Nibcos are rated 125 psi steam. Cheap valve but ok.
    @Jamie Hall Nipple with 2 flanges =spool piece
    Not all ball valves are steam rated.
    I always like Apollos...probably more $$$$$ than most
    They even make Carbon Steel ball valves like the Apollo 89-100 with options for 250 # steam
    I would be almost certain those Nibco's are made in China not that it matters
    cross_skier
  • delcrossv
    Just do the blowdown annually and they'll be fine.
  • cross_skier
    Just to be sure I picked up two Apollo 2" forged carbon steel ball valves for a nice price.  Those are critical valves.  I'll dump the Nibcos on eBay
  • ChrisJ
    ChrisJ Member Posts: 17,519
    I open and close my king valves yearly but have never used them.
    I wash everything out with a wand.
  • KC_Jones
    KC_Jones Member Posts: 5,939
    I have done 2 blowdowns on mine since 2014, with my water treatment it just doesn't get that dirty. The blowdown is....entertaining. It does blast the water out for sure.
    2014 Weil Mclain EG-40
