Reasons We Love Our Radiators
Steamhead
Steamhead Member Posts: 18,393
Thought I'd share this- The Lovely Naoko knows the best way to dry out her gloves.
Consulting
kcoppdelcrossvSteve Minnichcross_skierErin Holohan HaskellMarjPinardMad Dog_2IronmanSolid_Fuel_Man
  • cross_skier
    cross_skier Member Posts: 201
    Around here hot towels when you get out of the shower feels awesome
    Mad Dog_2
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    edited January 2022
    Cast is a blast!
    The kids rooms, run the same temp as the radiant slab downstairs.
    lkstdlMad Dog_2
  • mel57
    mel57 Member Posts: 9
    I remember, as a child, after a long hard day playing in the snow. Laying on top of one, drying  off, and thawing out. I miss that.
    CLambMarjPinardMad Dog_2
  • cross_skier
    Bringing life back into unique old objects with a lot of history
    MarjPinardMad Dog_2
  • flat_twin
    flat_twin Member Posts: 355
    edited January 2022
    Cast is a blast!
    Our Weil Mclain rads look like these six column ones that solid_fuel_man has. They're great for resting your cold tired butt on when you come in from the outdoors. Those rounded top rads don't look near as comfortable.
    Solid_Fuel_ManMad Dog_2
    Consulting
    Mad Dog_2
    hot_rod Member Posts: 27,290
    I’ve head say you can melt a cat on a radiator?
    JakeCKSolid_Fuel_ManH2OBandit603Mad Dog_2
    mattmia2 Member Posts: 16,412
    I just put one in my garage.
    hmm, that could be the solution to my not enough delta t across the unit heater to push as much heat as i need across the hx that isolates the glycol loop out to the garage.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    When visiting my daughter in Minnetonka, when the temperature, (with no wind chill), was -30 F outside, putting my hands on the Amtrol indirect hot water tank was heaven, after snow blowing.
    Interesting enough was the Burnham hot water boiler next to the tank, was not as warm!—NBC
  • PC7060
    PC7060 Member Posts: 1,780
    edited January 2022
    Haha, thought every one put the extra radiators in their shop
    Solid_Fuel_Man
  • Solid_Fuel_Man
    edited January 2022
    Of course all of these are heated by wood.... I sand blasted and painted them with automotive paint.
    @flat_twin good eye, those pictured are Weil McLain. I have a couple of square ARCOs as well. All 1950s salvage....the boring ones.
  • scott w.
    scott w. Member Posts: 226
    edited February 2022
    Seeing the infra red photo's of the rads that look like gold made me think of this question. Is cast iron the best metal for a radiator? If you could afford it what would be the upside and the downside (other than cost) of having a radiator made out of solid gold compared to cast Iron? Would most likely have to add other metals to the gold so it would not be to soft to connect to a threaded pipe. Just curious, would the gold radiator have more heat output than cast iron, copper, aluminium?
    Jamie Hall Member Posts: 27,218
    No... in fact, if it were shiny, it might have less -- perhaps much less! Consider heat shields in space...
    The heat output is related to the emissivity of the material, not the material itself -- so dull rough pretty much anything is going to be better than bright shiny pretty much anything.
    PC7060MarjPinard
  • bucksnort
    bucksnort Member Posts: 167
    I remember as a little lad after waking up sitting on a radiator downstairs just a cooking heat before breakfast. Brings back memories of joy. My home of the past 35 years has them. I couldn't think of any other way to have heat.
    DaveinscrantonMarjPinard
  • MarjPinard
    MarjPinard Member Posts: 11
    I saw the post of putting wet gloves on the rad and yes, it's so true and wonderful. My son comes over for AM coffee, puts his gloves on the rad to dry and warm up. Then he sets his coffee cup on the square plate on the rad to keep it warm while he drinks it! Yup, those rads are glowing as we enter the 4th week of single digit weather.
  • MaxMercy
    MaxMercy Member Posts: 594
    I grew up in a house with cast iron baseboard radiators and my current house has two low speed hydro-air handlers. I honestly don't feel the difference in comfort although my current house is draft free compared to the old one, so maybe that's the difference.
    One thing about the hydro-air that was nice was when we had no heat for three days during a early winter ice storm and the house was at 45 F. Not even 10 minutes after the power came back, warm tropical air was pumping out of the registers. Within half an hour we were close to 60 and it felt like 80 at that point.
    As a kid, I remember running in from the outside and sitting on the steam radiators in grammar school and later at high school on those bitter NE mornings. Nothing like baked ham on a cold winter day..
  • dermzcont
    dermzcont Member Posts: 1
  • jesmed1
    jesmed1 Member Posts: 1,425
    edited September 2023
    Speaking of how paint colors and sheens affect radiator emissivity, here's a blast from the past. Unfortunately it isn't very easy to read, but the chart at the end is interesting (click on the radiator-color pdf link). According to the chart in the link, a white enamel finish was just as good (and very slightly better) than unpainted cast iron at emitting heat (I assume that was by convection and radiation combined. I find that surprising, because I would have guessed unpainted black cast iron would be a better heat emitter than white enamel.
    https://heatinghelp.com/systems-help-center/does-the-color-of-a-radiator-matter/#:~:text=But have read in my,than same shaped colored gray.
    Dry out cats also
    CLamb
