Control water usage at shower and hose bib heads
SweatHog
Member Posts: 30
Has anybody employed a proportional control valve to regulate high water usage for showers and outside hose bibs? How reliable are they and is there a cheaper way to achieve the same result with, say, a zone valve and some sort of timer?
Most shower heads currently on the market have a flow rate limiting device built into them. It sounds more, though, as though you are looking to limit the total amount used at one time? There are a number of self-closing faucets and valves for that purpose.Br. Jamie, osb
Probably your best bet -- depending somewhat on how determined your water [mis]users are -- is going to be a regular shower head or hose bibb, and a zone valve on the feed controlled by a push button and timer located remotely. Digikey -- among other sources -- has a variety of time delay relays which can be used.Br. Jamie, osb
I find the best way to do this for showers is to have them pay for what they use.
Each unit gets a 40 gallon electric water heater.
When it gone they will get out. Also since its on their dime they will now conserve.
I recommend this to most landlords.
Its what happens when people get free heat and hot water.... they waste.
Both PIC and manual balance valves can be used to regulate flow to a fixed gpm. Make sure the valve is NSF certified low lead
Caleffi for one offers all their balance valves low lead as they get use in potable balance applications often.Bob "hot rod" Rohr
Thanks for the suggestions. Lots to investigate here...0
Flow switch on the hot water pipe when the flow starts the flow switch takes out the relay and kills the water heater
As far as the outside faucets /hose bibs a timer wired to a valve like they do at an air pump you have to pay and at a car wash when the time runs out0 -
You can always lower the water pressure0
You could install a device such as the Moen Flo0
