Control water usage at shower and hose bib heads
SweatHog
SweatHog Member Posts: 30
Has anybody employed a proportional control valve to regulate high water usage for showers and outside hose bibs? How reliable are they and is there a cheaper way to achieve the same result with, say, a zone valve and some sort of timer?
    Jamie Hall Member Posts: 26,269
    Most shower heads currently on the market have a flow rate limiting device built into them. It sounds more, though, as though you are looking to limit the total amount used at one time? There are a number of self-closing faucets and valves for that purpose.
  • SweatHog
    edited January 2022
    @Jamie Hall. Yes, I'm trying to address the latter issue: preventing long showers and open hose bibs after car washing and other activities.
    Probably your best bet -- depending somewhat on how determined your water [mis]users are -- is going to be a regular shower head or hose bibb, and a zone valve on the feed controlled by a push button and timer located remotely. Digikey -- among other sources -- has a variety of time delay relays which can be used.
  • kcopp
    kcopp Member Posts: 4,579
    I find the best way to do this for showers is to have them pay for what they use.
    Each unit gets a 40 gallon electric water heater.
    When it gone they will get out. Also since its on their dime they will now conserve.
    I recommend this to most landlords.
    Its what happens when people get free heat and hot water.... they waste.
    Larry Weingarten
    hot_rod Member Posts: 25,494
    Both PIC and manual balance valves can be used to regulate flow to a fixed gpm. Make sure the valve is NSF certified low lead
    Caleffi for one offers all their balance valves low lead as they get use in potable balance applications often.
  • SweatHog
    Thanks for the suggestions. Lots to investigate here...
    EBEBRATT-Ed Member Posts: 18,378
    Flow switch on the hot water pipe when the flow starts the flow switch takes out the relay and kills the water heater :)
    As far as the outside faucets /hose bibs a timer wired to a valve like they do at an air pump you have to pay and at a car wash when the time runs out
    pecmsg Member Posts: 6,387
    You can always lower the water pressure
  • Derheatmeister
    Derheatmeister Member Posts: 1,658
    edited January 2022
    You could install a device such as the Moen Flo
