Can I turn off a single radiator in my hotwater system?
Nick_Mo
Member Posts: 1
I have 3 radiators on the bottom floor of my house, and 2 on the top floor. None of my radiators have lockshield valves or thermostatic valves. I plan to figure out a long-term solution to balance my radiators more effectively, once I learn more about the system.
In the mean-time, as a short-term solution, can I just turn off one of the radiators on my top floor? The top floor gets too hot, and the bottom floor doesn't get hot enough. I have heard that turning off radiators in steam systems can cause issues with the pressure. Is this something I need to worry about with a hot water system?
Yes, you can safely turn off one of your radiators to balance the system without causing pressure problems.
The major concern is the possibility of freezing the radiator supply and return pipes, if they run in exterior walls or are exposed to cold drafts and you are in a cold climate. Hot water radiator valves are supposed to allow a minimum flow when closed to prevent frozen pipes, but this is sometimes not the case, especially if a system has been altered.—
Bburd0 -
- 50 Industry Classes
