Venting Risers...Because Why Not??
I'll be replacing the radiator valve and spud on my 2nd floor radiators. It dawned on me that it would be a good time to vent the risers going to these radiators. Between the runout and risers there is probably 15-20ft of 1-1/4 pipe going to these radiators.
My back-of-the-napkin math says that's about 1.5-2.0 cubic feet in the riser/runout to vent.
I have Big Mouth main vents and these radiators heat well....but I want the air out of my mains as quick as possible which made me think maybe getting the air out of the risers would help accomplish this.
I'd use a reducing Tee and a straight radiator valve with its matching spud. The fittings are cheap and I already have some good Gorton #1's lying around so this really wouldn't cost me anything. The Reducing Tee I am referring too looks like this:
I might have missed it, what's the question?
@ChrisJ
Hahaha....sorry, I tend to elaborate (ramble) TOO much sometimes. While I'm at it replacing the radiator valves I'd like to vent the risers. Do I need to? No. Do I want to? Yes.
The risers/runouts are 15-20ft long.
I'm wondering if this is a good idea or a completely unnecessary idea. I tend to be Captain Overkill most of the time.0 -
In my view it's an excellent idea. After all, when you really look at it from the viewpoint of the air or steam, a riser is no different from any other steam main.Br. Jamie, osb
I like it.AdmiralYoda said:@ChrisJ
I'm wondering if this is a good idea or a completely unnecessary idea. I tend to be Captain Overkill most of the time.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
@Jamie Hall @ChrisJ
I have seen people vent visors after the fact to correct the lack of steam getting to the 3rd+ floors and it usually involves drilling and tapping to get a vent installed somewhere.
I want to use a reducing Tee and a straight radiator valve to accomplish the same thing. It is good to know this is an option. Thanks!1 -
I'd agree with doing this, it would be a fascinating experiment honestly. The radiator vent would truly be only for the radiator. The idea of getting steam to every rad simultaneously would be much easier.1
@KC_Jones That was my thought exactly. There is even one radiator on the 1st floor with a rather long runout as well. It is a relatively inexpensive experiment with the only extra cost being a Gorton #1. And if for some reason it turns out to be a bad idea (unlikely) I can just plug the vent hole.
@cross_skier If I'm not mistaken the Gorton D and #1 has the same venting capacity, with the difference being the thread size. Sounds like a great choice either way.0 -
I did mine on a second floor riser that I re-ran just for fun. I think it's not necessary for 2nd floor. I'm sure it's faster to get steam, but it's not really noticeable at least for me.
I did one at the furthest spot on my system, but I put the tee between the spud and the rad. Seems to have improved things, I mean, how could it not?0
I also started with the furthest bathroom out. A hot bathroom radiator in the morning was a "must have" every winter morning. 2" main to 33' of 1-1/2" main with 12' of 1"riser to the tiny bathroom radiator.0
I would like to vent two of my 1 1/4" risers feeding the third floor radiators, but these recessed Cast Ray rads don't have the space for a tee with a vent on it since the valves are located below the rads, not on the side. The risers come through the floor with a 6-8" run outs from the valve to the radiator.
The risers are in the walls and only a small section of them- 20-24" where they connect to the main are accessible from my crawl basement crawl space. I have 22' risers feeding the 3rd floor rads which are currently vented with the largest orifice MOM vents but still take a couple of boiler cycles to heat up.
Thanks in advance for any suggestions.
@PhilKulkarni You can consider drilling the 6-8" runout and tapping for 1/8" angle vent such as a Gorton D.
I also used a tap, 1/4" npt0
That's an interesting idea. Is there a reason tapping the rad instead just above the spud wouldn't accomplish the same thing? Seems to me EVERY rad could benefit from 2 vents, a riser vent and a rad vent on opposite sides. Or am I, steam novice, missing something?jhewings said:@PhilKulkarni You can consider drilling the 6-8" runout and tapping for 1/8" angle vent such as a Gorton D.
I did 3 like the one above and 1 on a radiator (on the steam valve side about 6 inches above the steam valve because the above was not convenient). They are all "riser" vents though. I have 4 risers. I don't think my system needs 2 vents on every radiator. These are on the 3rd floor of a 3flat (Chicago). I am happy with these riser vents although an unexpected result was one of them erupts with loud hissing of air going back in after the boiler shuts down (every time). I don't mind it although I have read here a vacuum breaker on the main vent tree will solve this.0
@AdmiralYoda
1st floor not necessary
2d floor may or may not help
3rd floor ..do it
If your riser and radiator are both 1 1/4" you can use a 1 1/4 X 1/2 x 1 1/4 tee bush the 1/2" as needed for the vent
- 167 Indoor-Air Quality
