Drop Header for Single Riser
ranzerox
Member Posts: 55
I'm looking into piping a drop header for a GSA-075 that has a single riser. I find all the drop header discussions for double risers and I am wondering if its recommended to use a drop header for my singer riser boiler. If it's relevant, it's a parallel-flow system please note. Thanks and Happy Holidays!
=================================================================ranzerox said:I'm looking into piping a drop header for a GSA-075 that has a single riser. I find all the drop header discussions for double risers and I am wondering if its recommended to use a drop header for my singer riser boiler. If it's relevant, it's a parallel-flow system please note. Thanks and Happy Holidays!
If you have the room you could use a double drop header as well to increase speed of the dry steam delivery by using a secondary drop header that is one inch larger than the primary drop header as the steam will expand that much faster and the steam will dry that much faster as well with the drip pipe to the water level in the boiler.0 -
I put in two supplies on my small boiler just for experimentation’s sake but even if I had put in only one, I still would have done the drop header for sure.
…even though my experimentation showed my boiler never needs it. It’s just easy and may actually simplify pipe fitting.
I was gonna put two risers on this until our main guy had to shoot to another project (had to get busy- one day job). About 200 EDR, 36” riser into a 2 1/2” header, runs nice
4 -
Not advisable on the inferior Dunkirk design, GW!
Any problem using a street elbow when creating the drop? I'm thinking riser to elbow to street elbow. In all the pictures I've come across, its riser to elbow to nipple to elbow.
Thanks0 -
No, can't think of one -- if you can find a street elbow big enough and which increases the diameter, since you want the drop header (any header, if it comes to that) to be one pipe size larger than the riser.Br. Jamie, osb
@ranzerox
Trust me skip the street elbow. They are hard to get a wrench on and your risk crushing it unless you screw a nipple into it to prevent that. You would regret it.
A regular 90 is cheaper than a street 90. But you have to buy a nipple. In 2" your talking about $5-$6 more overall1
