Leak
Jonathan35
Member Posts: 1
in Biomass
There is water dripping down into my clean out by the lower door
Is it raining outside?0
You might wanna supply just a little bit more info.Bob Boan
My Crystal ball is out for annual maintenance repair, buffing and Polishing.0
That would not be a good idea- the ladies would never trust usEBEBRATT-Ed said:
Consulting0 -
There is water dripping down into my clean out by the lower doorIs this a moment of reflection?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
=================================================================Jonathan35 said:There is water dripping down into my clean out by the lower door
Hello Jonathan,
Does your Tarm have a Domestic coil in it?? It may be that you will need to take the skin off the boiler to look for the leak.
If the rubber gasket is leaking you will have to try tightening the nuts a tiny bit and if it still leaks you will need to drain the boiler and remove the coil and install a new gasket.
- 117 Geothermal
