Leak
Jonathan35
Jonathan35 Member Posts: 1
There is water dripping down into my clean out by the lower door
    pecmsg Member Posts: 7,064
    Is it raining outside?
  • Ironman
    Ironman Member Posts: 7,903
    edited December 2021
    You might wanna supply just a little bit more info.
    Bob Boan
    EBEBRATT-Ed Member Posts: 20,172
    @Ironman & @pecmsg
    Don't you guys have x-ray vision? LOL
    Ironman
    My Crystal ball is out for annual maintenance repair, buffing and Polishing.
  • psb75
    psb75 Member Posts: 1,130
    Chrystal balls are as expensive as combustion analyzers to send in!
    pecmsg
    Steamhead Member Posts: 18,497
    @Ironman & @pecmsg
    That would not be a good idea- the ladies would never trust us >:)
    Consulting
    Alan (California Radiant) Forbes Member Posts: 4,720
    Is this a moment of reflection?
  • leonz
    leonz Member Posts: 1,808
    Hello Jonathan,
    Does your Tarm have a Domestic coil in it?? It may be that you will need to take the skin off the boiler to look for the leak.
    If the rubber gasket is leaking you will have to try tightening the nuts a tiny bit and if it still leaks you will need to drain the boiler and remove the coil and install a new gasket.
