Wm aqua logic leaking from the sensor well
My wm 97+ 110 ct with aqua logic has extremely low water pressure coming out of all faucets (hot water) and is leaking from the sensor wells. Any ideas what may cause the leak and how to increase the pressure?
  • STEVEusaPA
    Is it leaking at the threads or leaking from a weld?
    Kasia
    EBEBRATT-Ed Member Posts: 20,090
    How old is it? I would remove the inlet and outlet fittings they are probably partially plugged. If it's leaking through the center of the well replace the well
    If it's leaking from the well threads remove it clean the threads and re dope it and install. Based on what you see you may want to replace the tank
    Kasia
  • Kasia
    Kasia Member Posts: 3
    It is leaking from inside of the well, from the hole the sensor goes into.
    My gauge is also reading pretty high 40 psi on standby and the hot water pressure is extremely low, so low that my washer throws a code when washing in hot. Is this all because of the well?
  • Kasia
    The system is maybe 8 years old.
    pecmsg Member Posts: 7,026
    You washer inlet valves have fine screens that may be plugged. Supply hoses sometimes have screens as well.
    How is the water pressure at faucets?
    Kasia
    Jamie Hall Member Posts: 27,257
    No, the problem with the low pressure isn't because of the well. You could check what the static hot water pressure is if you can fit a gauge to an outlet, but the guys above are right -- either the inlet of the outlet or much more likely both is plugged up.
    Kasia
