Wm aqua logic leaking from the sensor well
Kasia
Member Posts: 3
My wm 97+ 110 ct with aqua logic has extremely low water pressure coming out of all faucets (hot water) and is leaking from the sensor wells. Any ideas what may cause the leak and how to increase the pressure?
How old is it? I would remove the inlet and outlet fittings they are probably partially plugged. If it's leaking through the center of the well replace the well
If it's leaking from the well threads remove it clean the threads and re dope it and install. Based on what you see you may want to replace the tank1 -
It is leaking from inside of the well, from the hole the sensor goes into.
My gauge is also reading pretty high 40 psi on standby and the hot water pressure is extremely low, so low that my washer throws a code when washing in hot. Is this all because of the well?0 -
The system is maybe 8 years old.0
No, the problem with the low pressure isn't because of the well. You could check what the static hot water pressure is if you can fit a gauge to an outlet, but the guys above are right -- either the inlet of the outlet or much more likely both is plugged up.Kasia said:It is leaking from inside of the well, from the hole the sensor goes into.
My gauge is also reading pretty high 40 psi on standby and the hot water pressure is extremely low, so low that my washer throws a code when washing in hot. Is this all because of the well?Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England1
