Oil Usage calculation
11971STEVEusaPA said:152,761,574 btu's
1100 x 139,000
If you're trying to do a heat loss off it I would need your zip code.
On Long Island if you multiply gallons by 55 it gets you a WAG. It sounds crude but it works. My house uses 600 gallons a year, give or take. My house has has 80 feet of S/F baseboard, so the numbers jive. Radiation 40,000. WAG heat loss 33,000. Still waiting for someone to make a small enough boiler.2
Making some assumptions...I didn't have DDay entered in for the tip of the Island, I figured New Haven was close enough.
P.S Hey @Robert O'Brien did you get the files I sent you?
He said 1100 gallons...Jamie Hall said:You guys cheat. As a way to get a building's heat loss, that works just fine! But you do need a reasonably accurate fuel usage...
this young man helped on the beach house project so I’ll return the favor.I told him I’d sizing and help with the piping design.The HW is supplied by a zone valve. During the summer they run the 1st floor circ to get HW.I get to play with the pro press again
Well even if I'm off the smallest boiler will be a little too big. Maybe it's time to pop in an EK.
Moneys a bit tight but that’s my next post. Manufactures. My rough estimates were 80K input.0
What is the story with the thimble for the flue pipe? Looks strange in the picture. Masonry chimney?0
You need to put on an addition, or sell some capacity to a neighbor.R Mannino said:On Long Island if you multiply gallons by 55 it gets you a WAG. It sounds crude but it works. My house uses 600 gallons a year, give or take. My house has has 80 feet of S/F baseboard, so the numbers jive. Radiation 40,000. WAG heat loss 33,000. Still waiting for someone to make a small enough boiler.
Just trying to think outside the box
Mr.Ed
LOL :'(
They make small boilers that fire with a .17 nozzle.R Mannino said:On Long Island if you multiply gallons by 55 it gets you a WAG. It sounds crude but it works. My house uses 600 gallons a year, give or take. My house has has 80 feet of S/F baseboard, so the numbers jive. Radiation 40,000. WAG heat loss 33,000. Still waiting for someone to make a small enough boiler.
Just not in America.
2 -
- 120 Geothermal
