Switch to natural gas or stick with oil?
2»
  • ChrisJ
    ChrisJ Member Posts: 17,061
    JUGHNE said:
    Are we sure we know who our enemies really are?
    Not all are overseas IMO.
    Those damn forced air guys............. :D
    SlamDunkJUGHNEpecmsg
  • STEVEusaPA
    Jersey2 said:
    ..But the nice thing about NG is it burns cleaner than heating oil. An oil burner needs to have the oil filter and nozzle changed every year, and a good vacuuming every other year. It makes more soot. It is like a diesel truck vs gasoline truck.
    A modern oil burner, properly tuned, using ULSD Bio, burns cleaner than natural gas and is less harmful to the environment. Properly handling/storing the fuel, and double filtration means you don't need to change the filters/strainer/nozzle every year in a modern oil burning appliance.
    I change mine 2-3 years and only vacuum it if it's needed. Last time I went 4 years.
    Doesn't make soot if properly tuned, or makes a negligible amount.
    Efficiency numbers for modern oil are in the high 80's low 90's.
    Any modern gas appliance also requires maintenance.
    pecmsgHVACNUT
  • yesimon
    yesimon Member Posts: 45
    edited December 2021
    NG is most certainly cheaper than oil over the past 10 years. Significantly. For a few years the price difference was big enough to make you puke. Over the past few years the gap as shrunk.
    All it takes is the slightest instability in the Middle East and the price of oil will out pace the price of natural gas.
    We used to export more natural gas than we import. Not any more, sorry.
    Please see https://www.eia.gov/energyexplained/natural-gas/imports-and-exports.php
    US natural gas exports has dramatically increased in the last few years (last 5 years!). American consumers will no longer be insulated from prices in the global methane market in the future. Especially as many countries are turning to natural gas power plants as a quick & easy way to reduce carbon emissions and meet climate goals.
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,231
    @STEVEusaPA interesting, can you share your evidence?
  • STEVEusaPA
    NORA has published this, from their website (many times). Nora's problem is poor marketing. They used to run ads in print and on the radio.
    Hot_water_fan
