Cross Control connections
I cannot follow your description.
If you post a sketch showing which wires you have connected to which terminals, we can check your work."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I have spent the last multiple hours trying again to find a way to provide you with a drawing. I really just do not know how. I do not understand what you need to see.
There is really nothing to see. I have described the connections to both the controller and the wires to the Tekmar. I have shone you what the manufacturer shows. There just is nothing else I can give you.0 -
Sorry, I am unable to help. The wire colors mean nothing to me, my mind sees circuits. If I was doing this for myself, I would draw it out and then wire it."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
OK - I understand.
Any recommendation of where to go for help? It is really a confusing system for me. The connections are a requirement that I do not understand.
Floods and temperatures are not helpful.0
