Cross Control connections
2»
  • Zman
    Zman Member Posts: 7,611
    I cannot follow your description.
    If you post a sketch showing which wires you have connected to which terminals, we can check your work.
    Albert Einstein
  • Harold
    Harold Member Posts: 249
    I have spent the last multiple hours trying again to find a way to provide you with a drawing. I really just do not know how. I do not understand what you need to see.
    There is really nothing to see. I have described the connections to both the controller and the wires to the Tekmar. I have shone you what the manufacturer shows. There just is nothing else I can give you.
  • Zman
    Sorry, I am unable to help. The wire colors mean nothing to me, my mind sees circuits. If I was doing this for myself, I would draw it out and then wire it.
    Albert Einstein
  • Harold
    OK - I understand.
    Any recommendation of where to go for help? It is really a confusing system for me. The connections are a requirement that I do not understand.
    Floods and temperatures are not helpful.
