Copper pipe electrolysis
I have a hot water copper pipe from my water heater which is touching my furnace’s Bvent exhaust connector pipe which leads to my chimney. It is an extremely tight space and difficult to move the Bvent or the pipe. Is anyone aware of an approved or appropriate wrap of any sort that a plumbing inspector would approve. A local plumber told me there was no way an inspector would approve it with a scrap of rock wool jammed between them. It does look unprofessional and though it’s in their tight, it doesn’t look like a fixed or permanent solution, so I agree that it would likely fail.
  • davidken
    davidken Member Posts: 2
    Typo: It does not look professional. (With rock wool stuffed between the pipe & the Bvent)
    mattmia2 Member Posts: 15,067
    you could use a piece of kaowool or a muffler bandage or get some high temp fiberglass without the binders. i really don't thing an inspector would notice if it was just enough to isolate the 2. ordinary rockwool probably has flammable binders in it.
    pecmsg Member Posts: 6,673
    We need pictures
    mattmia2Zman
    EBEBRATT-Ed Member Posts: 19,172
    easy to move the pipe 1/2 an inch. 2 45s and 190 degree elbow
  • STEVEusaPA
    If it’s b vent why can’t it touch the pipe, with just a small piece of kaowool, barely noticeable between vent and pipe? Last I checked copper isn’t combustible.
