Triangle Tube instinct
Chip_8
has anyone had any feedback on these boilers yet? I am looking to install one for a customer that is requesting it.
I don't have direct experience with one. It sure looks like they rearranged a prestige and gave it a much needed 8 to 1 turndown.
https://www.triangletube.com/getmedia/4856b267-3ba7-499b-907e-ba20abac7011/2019-14-Instinct-Launch-Literature-(rev).pdf?ext=.pdf"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I am in tech support at triangle tube if you have any questions I would be happy to speak to you
you can reach me 8-5 weekdays 856 228 8881 ex 155
hope I can help
Ed Nelson0 -
The Instinct is not a "rearranged Prestige", it uses a new heat exchanger and combustion design and new ignition system. Have also gone to some new component manufacturers . All new product backed by the strongest warranty in the industry
What kind of HX? Tell us more about the combustion design and ignition system. Is labor covered in the new warranty?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
@Mark_AMark_A said:Hey Chip,
Thanks for your interest!
Please fill us in on the revolutionary new product. On the surface you have a stainless firetube boiler with turndown ratios similar to the other firetubes on the market. The controls look very similar to the Prestige.
Hypothetically, does the "strongest warranty in the industry" cover labor to replace the heat exchanger when the studs on the top spontaneously pop off after 5 years? 10 years?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
BTW, I have a 15 year old TT Prestige in my house. I have had no major issues. Triangle Tube had the lions share of the market back then. R&D as well as local training and support has fallen of in recent years."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I have installed about 12 or more of the Prestige Excellence boilers and all was good. During the sale of the company all of the local wholesalers dropped the brand because they were not paying out on warranty parts. I switched to the IBC GL series boiler and it is extremely similar. My understanding is some of the engineers came from Triangle Tube. Technical support was very good. The boiler is much better than many others on the market.0
Hmmmm...so what to do? IBC DC series or TT Instinct? Seriously considering both, trying to decide...any more feedback, pos/neg?
Seems like TT better turndown ratio ( 8:1 vs 17:1; GPM (5 vs 3.2), and warranty...local dealer gets 7 years parts AND labor.
IBC unit has 2 in 1 design in cast aluminum heatX, but TT has SS heat X.
* TT installer is big, reputable company; IBC not as much.
TT made in Belgium, but based in NJ( I'm in NY); IBC in Canada.
Does any of this matter? Am I overthinking this?
Appreciate any feedback.
TIA0 -
I am a big fan of IBC especially the HC/ DC.
If you have the room I would opt for the HC and have a separate indirect water heater off the boiler.
Less wear and tear on the boiler and more consistent hot water. The HC has only 5 moving parts.
That being said its the installer and which unit he can service easily and get running if there are issues.
2 -
We have limited local support for IBM or NTI. We’ve installed several Instinct Boilers and generally had good luck with them. I think a few sensors have failed, but no major issues like the Prestigue.
That being said I’ve seen some horribly installed Prestigue boilers that are humming away 15 years later.0 -
The instinct has a lot of plastic0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
