circulation pump
jwjojo
Member Posts: 1
We have a steam boiler with a loop and a taco 007 circulation pump. We have gone through 2 pumps in a short period of time. Taco says the pump is not good for steam boilers, which is true! I was told to get the bronze colored pump because they can withstand the heat and steam. I was hoping someone could tell me which one to purchase. Thank you in advance. Joana
The Bronze 007 has been discontinued I would think the stainless model would be a good replacement.
One of the Steam or Taco folks that visit the site could probably confirm.
https://www.supplyhouse.com/Taco-007-SF5-007-Stainless-Steel-Circulator-1-25-HP-15054000-p"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
Even if you use a Stainless circ if you are using this on the Condensate return line you should install a devise such as the Fernox TF 1 prior to the Circulating pump so that the circ is not subject to ferrous materials and sludge.0
As said before, the stainless 007 would be best for your system. Cleaning the water is never a bad idea and also make sure the circulator is as low to the ground (if not lower) as you can get it. Even better if a heat exchanger is used and the circ is on the heating side of the heat exchanger.
Dave H.Dave Holdorf
Taco, Inc
Why is there a circulator on there in the 1st place?jwjojo said:We have a steam boiler with a loop and a taco 007 circulation pump. We have gone through 2 pumps in a short period of time. Taco says the pump is not good for steam boilers, which is true! I was told to get the bronze colored pump because they can withstand the heat and steam. I was hoping someone could tell me which one to purchase. Thank you in advance. Joana
- 123 Chimneys & Flues
