What do you call these?
Alan (California Radiant) Forbes Member Posts: 4,639
edited October 2021 in THE MAIN WALL
.........and where do you get them? Thermostat wire sleeve?
Edit: I just noticed the part number in the picture and found them on Amazon. It's called a "Black Universal Bushing".
STEVEusaPAZman
  • Big Ed_4
    Big Ed_4 Member Posts: 3,360
    edited October 2021
    Hozewatser :)
  • STEVEusaPA
    Your hands are too clean…
    JUGHNEPC7060
    mattmia2 Member Posts: 15,542
    grommet. maybe a bushing
  • JUGHNE
    JUGHNE Member Posts: 11,511
    I end up with a can full of those type of things; snap in grommets or cord type locking grommets.
    There are always some that come with FAF's.
    Even plastic KO closers that make an electrical inspector blink and think....."now is that UL approved?"
    It was good enough for factory equipment wasn't it??
    I have taken the plastic KO snap in closers and drilled a hole with a step bit to run low voltage thru.
  • HomerJSmith
    HomerJSmith Member Posts: 2,706
    edited October 2021
    You gotta be kidding me. It's a insulation bushing for a single wire such as a thermostat wire. It fits into a 1/2" panel knock out.
    You should be able to get them at any electric supply house. I save them, when ever I can, handy.
    hot_rod Member Posts: 26,574
    Wire grommets, find them at box and hardware stores. I like the rubber ones best, a lip on both sides to keep them secure
  • ratio
    ratio Member Posts: 4,176
    ½" KO booshing, available in many sizes. I prefer the ones without the fingers inside, I can get wires through them easier. Bridgeport cat # 9792 for the ¾" size.
