Replace Ancient Cast Iron Steam Radiator with Modern Flat Unit
douglass
Member Posts: 1
Hello,
I am renovating a condo in a pre-war apartment building in NYC. I want to replace a single pipe steam cast iron radiator with a modern flat wall mounted units. Does anyone have any advice/experience with this kind of project? Vendor recommendations would be helpful as well. Thanks.
Do you have independent control of the steam delivery to your unit? Basically your own thermostat?0
- 117 Geothermal
