Replace Ancient Cast Iron Steam Radiator with Modern Flat Unit
Hello,
I am renovating a condo in a pre-war apartment building in NYC. I want to replace a single pipe steam cast iron radiator with a modern flat wall mounted units. Does anyone have any advice/experience with this kind of project? Vendor recommendations would be helpful as well. Thanks.
  • KC_Jones
    KC_Jones Member Posts: 5,939
    Do you have independent control of the steam delivery to your unit? Basically your own thermostat?
    2014 Weil Mclain EG-40
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,730
    Consider Runtal for this.
    Retired and loving it.
    Ironman
  • Ironman
    Ironman Member Posts: 7,927
    A modern steel rad may be nicer in appearance, but it doesn’t have the mass of a cast iron rad and it may perform differently even if it has the same btu rating.
    Bob Boan
    KC_Jones
