Vaporstat Model
I have read past posts on vaporstat with range of 16oz max, If I want cut in at .5 psig (8oz) and cut out at 1.5 psig (24 oz) how do I do that with a 16 oz max vaporstat?
Can anyone recommend a vaporstat model for .5/1.5 psig? If not how about a pressuretrol model and best place to get one?
    Jamie Hall Member Posts: 27,751
    For that pressure range you need the 0 to 4 psi vapourstat. L408J1017
    mattmia2 Member Posts: 18,021
    Let's back up and ask why you want to run it that high?
