Please HEEEEEEEEELP!!!!
pupsdad
Member Posts: 16
in Oil Heating
I need help reconnecting!!
My electrician came to install a new aquastat..... disconnected ALL of the wires to my furnace - triple aquastat- thermostats and zone valves. He left with some personal emergency 2 days ago and never came back and I can't reach him.
lux tx9600ts - 24v trans- taco 570 zone valve - oil furnace - L8124A1007 triple aquastat
- water tank
- water tank
Say what? Did he label any of the wires? Reconnecting all of that properly (it's a boiler, by the way, not a furnace) really is a job for a knowledgeable HVAC tech., not an electrician -- and you need one. It's much too easy to get things hooked up wrong, and the best outcome would be it doesn't work... the worst would be you could end up damaging some kind of expensive stuff...Br. Jamie, osb
or burning the house down or blowing it up if a safety is bypassed and the thing that safety protects against happens.0
(Agreed) All the wires are connected to their respective parts and easily traceable so knowing what wire to what isn't my issue. which wire to which is my issue.0
all the kill switches are connected and working fine. it's everything past those I'm screwed on0
Now that the obvious has been covered is anyone willing to respond with anything helpful?0
Does this help?
not even a little0
oddly enough though I have one of those on hand. it's one of the parts for the radiant flooring that's supposed to be installed when we rehab the basement.
I have a test pen. right above the BOILER. 1 lux to the 1st floor, water tank stat, 24 vl trans,
There are too many variables, without actually being on site to see what’s actually there, you may be grasping for something that’s not gonna happen.
I have a hard enough time when a technician calls with a simple control wiring problem trying to get it sorted out over the phone; trying to tell a HO over the internet is just not a good approach.
Where are you located? We may be able to recommend someone.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
I honestly don't think that anyone would be willing to suggest connect x to y without looking at it. Way too much liability. Sorry.pupsdad said:Now that the obvious has been covered is anyone willing to respond with anything helpful?
Ya. it makes sense. Just can't get anyone out here for 2 more days so just desperately trying to figure out what to do for heat and baths for the kids.0
I was just hoping I could find someone that could run me a diagram if I gave them the list of parts. I figured it was a long shot but still have to try.0
Central NH0
You could try the triple aquastat instructions to see if there is a wiring example with your components but it would be up to you to be very sure of what is hooked to what and there are some safeties that should be tested to make sure they cut the burner when you are done.0
This is about as simple as it gets.
The starting point is R or 24v at the transformer to R at the thermostat.
C on the transformer to 2 on the zone valves.0 -
Do I use jumpers going from 2-2 or nut together. What about the green from the thermostat? The zone valve for the water tank has 3 wires but thermostat for the water tank has 2. Is the other transformer even needed with the triple stat? There's literally 1 3 wire thermostat and zone valve for the house and 1 for the water tank.1
So the end switch connects to 1 and 3 and whatever the end switch is powering must be powered by the thermostat? This gets much more confusing when there are multiple xfmrs involved like with zones off a hot water loop off a steam boiler.0
First of all, what happened to the last one that you need a new one?
Just get someone who knows what they are doing. Your full service oil company can easily get you up and running, unless of course you only use discount companies with no service.There was an error rendering this rich post.
Was your electrician a self employed one man shop or did he work for/with some company?
If you can get in contact with him, he may have a buddy who is capable to finish the job.
I have been in his shoes in the past and was able to contact someone to finish what I started before the personal emergency.0 -
I figured it out. I found out my brother in-law has a friend that works for a local PROFESSIONAL HVAC company. I put it together and dropped him a few buck to swing over to look it over before I started anything up. He was both appalled at how the last guy left it and impressed that I had it 99% together properly. He said ALL of the same things and more you guys did....Now my MAJOR water issue is trying to get my 2 boys to take a bath, lol. Thanks All. I appreciate you taking your time to help.4
for those wondering about the 1% it was just him busting my balls about forgetting to put the batteries back in the thermostat0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 959 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
