Chimney-As-Chase
JohnNY
Member Posts: 3,368
Hello all,
I'm having trouble finding a National Fuel Gas Code for repurposing a masonry chimney to be used as a chase containing not only (either) CPVC/Polypropylene/AL29-4C boiler venting to the roof but also a gas line to a rooftop generator and an electrical conduit to the same generator all in the same chase. This can't be an approved installation but I can't illustrate it to the building. Any guidance to a defining Code is appreciated.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
What if it was a wooden chase boxed in by sheetrock? That would pass. Just because it used to be a chimney I don't see a problem.
Is this existing or a proposed retrofit?0 -
My only concern is the Fuel Piping! It "May" have to be double piped and vented.0
Is this a commercial building?
I think chapter 7 of the IBC addresses it."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 120 Geothermal
