Chimney-As-Chase
JohnNY
Member Posts: 2,917
Hello all,
I'm having trouble finding a National Fuel Gas Code for repurposing a masonry chimney to be used as a chase containing not only (either) CPVC/Polypropylene/AL29-4C boiler venting to the roof but also a gas line to a rooftop generator and an electrical conduit to the same generator all in the same chase. This can't be an approved installation but I can't illustrate it to the building. Any guidance to a defining Code is appreciated.
Contact John "JohnNY" Cataneo, Master Plumber for Consulting Work
Or for plumbing in NYC or in NJ.
Or take his class.
Or take his class.
What if it was a wooden chase boxed in by sheetrock? That would pass. Just because it used to be a chimney I don't see a problem.
Is this existing or a proposed retrofit?0 -
My only concern is the Fuel Piping! It "May" have to be double piped and vented.0
Is this a commercial building?
I think chapter 7 of the IBC addresses it."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Or take his class.0
- 117.6K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 402 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 679 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 11 Recall Announcements
