If our community has helped you, please consider making a contribution to support this website.  Thanks!
On-Demand Thermostat for Buderus Logamatic 2107
                    JGogu
                    Member Posts: 1
                    Hello,
there is any way to adapt/trick the Buderus Logamatic 2107 to use it with a normal on-demand room thermostat?
BR,
J.Gogu
BR,
J.Gogu
            Um.... well, it's not really intended to operate with a conventional on-demand room thermostat, since all of the benefit from using it comes from it's ability to modulate the circulating water temperature in response to the room and outdoor temperatures in a continuous way.
 What is the objective of the change to a traditional on/off thermostat?Br. Jamie, osb
 Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England1
            Sure you can. I have a multizone system with traditional thermostats and a 2107.
 I have considered converting my largest zone to constant circulation and using the Buderus wall control for that zone but haven’t ever gotten around to it.
 All that being said, you may lose some functionality if you change your setup. I’m sure some of the pros here can provide more insight.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
