Running MOD-CON boiler for Radiant Heat on generator during power outage-Any Suggestion?
hcpatel78
Member Posts: 157
Hi All,
I am just exploring the back up generator for my house. I also have radiant heat with Mod-Con boiler install which uses Natural Gas as a fuel. Do anyone have experience with the generator using to run this kind of the deliciated full of electronics combi boilers without damaging any electronics?
I was just reading that most of the generator is not supplying clean power (mean has Total harmonic distortion is around 11 to 15%) except those expensive inverter generator so...
I have Noritz CB199 model of Mod-Con and Grundfos Alpha II circulator in Radiant heat system.
Any advice...?
Thank you,
hiren
Any advice...?
Thank you,
hiren
Thank you,
Hiren Patel
Hiren Patel
If you want to be safe -- particularly with a less expensive generator -- your best bet is to run the boiler through and UPS. Two advantages -- first, it will clean up the power. Second, it will carry the boiler for a while while you get the generator running. But get a good one, which produces sine wave power. They aren't all that cheap either, of course, but APC makes some good ones.
You may also be able to find some older -- like, very older -- brush excited generators which have pretty clean power.Br. Jamie, osb
If it were me i'll roll the dice, but I would look for a used full time online UPS that just needs new batteries.0
That would work, if it worked at all!mattmia2 said:If it were me i'll roll the dice, but I would look for a used full time online UPS that just needs new batteries.
I have a whole house Koehler. Works fine. Dont go cheap.
We installed a Viessmann WB2A 11/44 about 15 years ago in Camp Hale Colorado..
This Off grid system is powered via a PV system with a backup Kohler generator switched via Outback..Back then Viessmann did not approve of this installation.
To protect the boilers Electronics and give the boiler a good sine wave we installed a APC UPS and never had any issues.1 -
Great suggestions. Thank you all.Thank you,
Hiren Patel0
