Trying to build menorah or antler for multiple maid o mist #1
danmasri
Member Posts: 11
I have an approximately 55' run single main measuring 2.5" in one family home and currently have one clogged vent. I would like to get multiple maid o mist #1s as discussed on this forum. I think I can replace current valve with one maid o mist but was hoping someone had an idea of building menorah or antler to get multiple main vents given limited clearance. Current piping is 3/4".
Come out of the 45 with a street El pointing off to one side, aimed very slightly off horizontal up (to allow drainback). Close nipple, T, vent on leg. Close nipple, T, vent on leg. Close nipple, T, vent on leg... rinse and repeat as desired.Br. Jamie, osb
Right now I have about 4" above the 45" elbow. So if I take off the vent and put a 90 degree elbow won't I cut from my 4" clearance and not have room to put in the vents. Was told I need about 4" to get maid o mist #1 in.
What if I turned the 45" to make it horizontal instead of vertical and then started with the close nipple, T etc. Would that work or not enough height distance from main.0 -
You can lower the height (1/2" or more) by putting a union right after the last 45. That lets you install the vents before fixing the antler in place.
3PSI gauge0 -
I can't see what you have below that 45?
On mine, there's a nipple from the steam main into a 45 to get around a joist and that originally went into another 45. I removed the 2nd 45 and replaced it with a tee which goes to several tees on each side to give me 5 vents from a single 3/4" connection.
I didn't have much room, but it fit and on my system I haven't had any issue with water or debris.
Here's a recent picture I have on hand that shows the piping.
It's not great, but it shows you what's what.
My suggestion will give you ample distance to put in the vents, though I really like the idea of a union right after the street elbow before the first close nipple. Also enough height above the main. In fact, it's almost exactly the same vertical dimension you have now. Unlimited number of vents -- just keep going along parallel to main.Br. Jamie, osb
Another option for adding taller air vents is to "box up" between floor joists.
You see this on occasion, it can be done and finished out quite well if wanted.
Then you pipe off the main off to the raised box up. You could gain almost a foot of clearance.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
