Carlin EZ Gas Conversion Burner or combo unit
Share77
Member Posts: 1
I have peerless boiler which has remaining life of 15-20 years. Wondering if I continue to use Peerless boiler with Carlin EZ gas conversion burner or completely switch over to navian combo. I was said that navian combo unit provides much more efficiency compared with conversion burner option. Looking for your guidance /inputs on this.
I would stay away from Navien and any combi unit but especially Navien.If your really looking into making a boiler change and if any Energy Kinetics dealers are in your area I would go with Energy Kinetics.0
A Peerless boiler should last a long time- longer than any Navien or similar unit. If I had your house, I'd go with the EZ-Gas.
Which model Peerless do you have?All Steamed Up, Inc.
Consulting0 -
So you are currently using oil?
How is domestic hot water made? Tankless coil, indirect, direct fired?
IMO, any combi would be a last resort. I would do a high efficiency boiler with an indirect and outdoor reset first.
If you're looking to convert, then as @EzzyT mentioned, look into the Energy Kinetics Frontier or Resolute. It can be installed now with oil, and easily converted to gas later.0 -
And unless your old boiler is really poorly maintained, don't expect a huge efficiency gain with any of the possibilities.Br. Jamie, osb
Stay with what you have. I am assuming you already are burning gas.0
