Carlin EZ Gas Conversion Burner or combo unit
Share77
Share77 Member Posts: 1
edited July 2021 in THE MAIN WALL
I have peerless boiler which has remaining life of 15-20 years. Wondering if I continue to use Peerless boiler with Carlin EZ gas conversion burner or completely switch over to navian combo. I was said that navian combo unit provides much more efficiency compared with conversion burner option. Looking for your guidance /inputs on this.
  • EzzyT
    EzzyT Member Posts: 1,379
    I would stay away from Navien and any combi unit but especially Navien.
    If your really looking into making a boiler change and if any Energy Kinetics dealers are in your area I would go with Energy Kinetics.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    Steamhead Member Posts: 18,345
    A Peerless boiler should last a long time- longer than any Navien or similar unit. If I had your house, I'd go with the EZ-Gas.
    Which model Peerless do you have?
    Consulting
    HVACNUT Member Posts: 7,349
    So you are currently using oil?
    How is domestic hot water made? Tankless coil, indirect, direct fired?
    IMO, any combi would be a last resort. I would do a high efficiency boiler with an indirect and outdoor reset first.
    If you're looking to convert, then as @EzzyT mentioned, look into the Energy Kinetics Frontier or Resolute. It can be installed now with oil, and easily converted to gas later.
    Jamie Hall Member Posts: 27,112
    And unless your old boiler is really poorly maintained, don't expect a huge efficiency gain with any of the possibilities.
    EBEBRATT-Ed Member Posts: 19,966
    Stay with what you have. I am assuming you already are burning gas.
