The record- air filter
GW
Member Posts: 5,060
Pulled this puppy today and slipped in a freshie
I just admired it and put the cover back on😀2
@GW
Posting that picture is similar to guys who post dyno videos but never show the results.
No picture of how dirty the actual filter was? I feel like I was ripped off.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Chris, LOL, I will never make that foxpaw happen again
I may drive into the dumpster at the shop and see if I can retrieve it
Seems like there might be a glitch, is this going to post twice?0 -
Got a call many years back and I don't rememebr if it was heating or cooling but told the customer that it sounding like all they needed was a new filter. They called back to say they had replaced the filter and it still was not working. I went by and there was in fact a new filter installed that still had the plastic wrap on it. No I did not tell them.0
It was a home with 8 Irish Wolfhounds and an owner that probably had never heard of an air filter."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
@Zman Does this filter have a strange lifeform growing on the right side?
Looks like a cross between a bird, a squirrel, and a rat
3 -
just a tumble weed , , ,known to beat dead horses0
Wow that is some gnarly looking imagery. The 2010 filter was quite tame in comparison. No build up at all, just a bit dark. Small condo, 60 something-year-old couple.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
