Wet return pipes
GraceMaria
Member Posts: 8
Please, if a Pro can advice me about the wet return pipe in my boiler system! Thank you in advance for your kind help! I'd like to know what is best and durable in the wet return in the boiler, copper or black pipe?
The wet return in my boiler was black pipe who got rotten after 25+ years. Last week, (May 6th, 2021) I hired a plumber and he replaced the wet return line and used copper pipe! Before he started, I told him that I need the black pipe as it was, but he said cooper pipe is more expensive therefore better.
(Without asking he eliminated the drain that was in the floor!) On Saturday 8th, I turned the boiler on and the water feeder didn't stop calling for water. I checked and found the floor in the next room completely wet. The leak was coming from the welded elbow inside the wall. He came yesterday, (May 13th) to fix the leak and he used hot and cool welding but I'm not confident it will last. The boiler wasn't in use, it's off, but today is empty and the copper pipe have a leak in another place. Advice please! Much appreciated!
Can you send some pictures of the pipes you are talking about?
He eliminated a drain in your floor???NJ Steam Homeowner.
@GraceMaria
Copper is fine for a wet return and will last longer.......not an issue. Copper should not be used on the steam supply so you are ok the way you are.
Problem is in your plumbers workmanship........it's lacking. And if it had a drain valve before he should have put one back.
try" find a contractor" on this site and post your location if you can't get this resolved0 -
When I asked him about the drain valve, He said that I don't need the drain in the floor. That this feature was optional.My main concern was because I have to make a new flooring and I don't want to be damaged because a leaking problem next winter.Thank you so much all for your kind help! I'll try to find a contractor here when I need one! Thanks!0
Copper piping is good for the wet return pipes, but should be resting on bricks, and not just lying on a concrete floor, where it can react chemically with the lime.
Its diameter appears small as well, so may need annual flushing out, through that missing drain valve.
Also I would route it in such a way as not to be a tripping hazard.—NBC0 -
I have seen some nasty work in my time but this comes close to taking the cake.
This guy calls himself a plumber, I don't think so. I had helpers with one year experience that soldered work for domestic water that had no leaks.
If I were you I would try to find a contractor that can do the work and guarantee no leaks. Additionally, the copper pipe should be no less than 1" pipe.
I would have the contractor put 2X4" blocks of wood under the pipe and securer the pie with c clamps.
The copper pipe should not lay flat on the floor, additionally beware of tripping hazzards.
Jake
Steam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
