Check O-ring before you press
sunlight33
Member Posts: 378
Viega?sunlight33 said:Was about to install this fitting today then realized a section of the o-ring is missing.
Yep, first time happened to me.0
Before I press? Yes! AND....at the supply house sales counter, TOO!
Thanks very much for the "heads up" sunlight33.0 -
Wow!0
Never.. in all the 40 plus years that we have been pressing have we ever encounter this!sunlight33 said:Was about to install this fitting today then realized a section of the o-ring is missing.
Question: Are you "Dryfitting" ?
Viega would want to know about this !0 -
Super sized leak path😂Bob "hot rod" Rohr
I have had a press-fitting without the "O" ring A few years ago. Ever since then I always check.0
Viega invented ProPress in 1989, what were you pressing before that? We don't even press much but I see torn or missing o-rings almost monthly. It's habit to check every fitting nowDerheatmeister said:
Yes the year was approx.1981 ...While in my trade as a pipe fitter in Bad Homburg v.d.h near Frankfurt Germany we started using a pressable fitting made by Mannesman ..GroundUp said:
Sooo..... NO ....Viega did not Invent Pressable fittings..
- 50 Industry Classes
