Check O-ring before you press
sunlight33
sunlight33 Member Posts: 378
Was about to install this fitting today then realized a section of the o-ring is missing.
STEVEusaPAAlan (California Radiant) Forbes
    pecmsg Member Posts: 7,370
    Viega?
  • sunlight33
    Yep, first time happened to me.
  • psb75
    psb75 Member Posts: 1,155
    Before I press? Yes! AND....at the supply house sales counter, TOO!
    Thanks very much for the "heads up" sunlight33.
  • Ctoilman
    Ctoilman Member Posts: 105
    Wow!
    EBEBRATT-Ed Member Posts: 20,655
    I guess they don't charge enough for the fittings :)
    I'll stick with my torch
    Larry Weingarten
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Never.. in all the 40 plus years that we have been pressing have we ever encounter this!
    Question: Are you "Dryfitting" ?
    Viega would want to know about this !
    hot_rod Member Posts: 27,971
    Super sized leak path😂
  • Intplm.
    Intplm. Member Posts: 3,102
    I have had a press-fitting without the "O" ring A few years ago. Ever since then I always check.
  • kcopp
    kcopp Member Posts: 4,711
    It happens. We have all seen plenty of defective pvc, copper and black fittings.
  • GroundUp
    GroundUp Member Posts: 2,538
    Viega invented ProPress in 1989, what were you pressing before that? We don't even press much but I see torn or missing o-rings almost monthly. It's habit to check every fitting now
  • Derheatmeister
    Yes the year was approx.1981 ...While in my trade as a pipe fitter in Bad Homburg v.d.h near Frankfurt Germany we started using a pressable fitting made by Mannesman ..
    Sooo..... NO ....Viega did not Invent Pressable fittings.. :/
