removing all parts of check valve from circulator
Nom_Deplume
Member Posts: 94
Hello...I am replacing a failing Grundfos 15-58 FC circulator with the same model. One of the isolation valves contains a check valve. Grundfos manual says to remove the check valve in the circulator with needlenose pliers and to make sure I get all parts out.
I took most of it out, but, there is a ring at the back of the check valve (white ring in photo) that is the same color as the rest of the check valve, but which cannot be pulled out with a needlenose. Is this supposed to come out, i.e. does it interfere with the flow? If yes, how do I take it out? I considered melting it with a propane torch but then decided to ask here instead. Just joking. Many thanks! (PS I am the homeowner.)
It's hard to get it to pop out, but it'll come. Pry with a screwdriver like suggested above, but try to not scratch the casting when it pops out.0
Or the other option is to take a hacksaw blade and cut from the middle to the outside. That will loosen up the plastic.0
Or any piece of stiff wire and bend a hook in the end. Are we sure that is part if the check valve and not some sort of orifice?0
Yes, it's part of the check.0
But some muscle into it, it will come out with a screwdriver. I recall my leatherman tool (needle nose) works a little better too, just gotta pry it out0
Thanks everyone! None of the tools I had (pick, screwdriver, needlenose, handsaw) got a grip on this thing. Finally I drilled a small hole in it and then cut it open by pushing the rotating drillbit sideways. It is quite hard plastic. I blew on the other end to get the plastic chips out, but can only hope I got all of them.
- 109 Chimneys & Flues
- 975 Plumbing
- 387 Solar
- 17 Recall Announcements
