HVAC recommendation Western MA
Etoile
Member Posts: 20
Can you recommend a seasoned competent HVAC pro for Western MA, Berkshire county? The contractor listed on the site for this zip code will not travel this far.
Please help!
Thank you!
Please help!
Thank you!
What kind of system? If it's steam try Charles Garrity ( @Charlie from wmass ) -- he's in Springfield, but I know he travels that far. Does hot water, too, but I'm not sure about AC or heat pumps.Br. Jamie, osb
I do not service AC or warm air direct fired heat.I do service hydro air systems, steam, and hot water.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
Try @GW not sure he's in franklin county but may not go as far as you need0
Sorry, we stay in a 20 minute radius. We can travel if the budget allows but most folks aren’t happy to pay us to drive. Thanks Ed0
I didn't think you did...Charlie from wmass said:I do not service AC or warm air direct fired heat.I do service hydro air systems, steam, and hot water.
Woah, this is the issue we’re encountering. It’s not an emergency, with two issues that want correcting. Please help!0
I'm in Berkshire county but I would have to know the system type before I could make a recommendation.
There are two separate issues-
1. Gas powered forced water boiler with baseboard heating.
2. Noritz tankless hot water heater.
I can send photos, and more detail if that would be helpful.
Thank you so much!
Look forward to hearing from you.0 -
Ah. Now we're getting somewhere. I believe that Charles Garrity, whom I mentioned before, would work on at least the heating system.
Could we, perhaps, be allowed to know what sort of work needs to be done? What the problems are? We might just be able to be more helpful...Br. Jamie, osb
- 50 Industry Classes
