HVAC recommendation Western MA
Etoile
Etoile Member Posts: 20
Can you recommend a seasoned competent HVAC pro for Western MA, Berkshire county? The contractor listed on the site for this zip code will not travel this far.
Please help!
Thank you!
    What kind of system? If it's steam try Charles Garrity ( @Charlie from wmass ) -- he's in Springfield, but I know he travels that far. Does hot water, too, but I'm not sure about AC or heat pumps.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,430
    I do not service AC or warm air direct fired heat.I do service hydro air systems, steam, and hot water.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
    EBEBRATT-Ed Member Posts: 20,485
    Try @GW not sure he's in franklin county but may not go as far as you need
  • GW
    GW Member Posts: 5,188
    Sorry, we stay in a 20 minute radius. We can travel if the budget allows but most folks aren’t happy to pay us to drive. Thanks Ed
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
    I didn't think you did...
  • Etoile
    Woah, this is the issue we’re encountering. It’s not an emergency, with two issues that want correcting. Please help!
    mattmia2 Member Posts: 17,476
    @Etoile, if you would answer the question about what type of system it is, we could recommend someone.
    Charlie from wmass
  • Grallert
    Grallert Member Posts: 1,148
    I'm in Berkshire county but I would have to know the system type before I could make a recommendation.
  • Etoile
    There are two separate issues-
    1. Gas powered forced water boiler with baseboard heating.
    2. Noritz tankless hot water heater.
    I can send photos, and more detail if that would be helpful.
    Thank you so much!
    Look forward to hearing from you.
    Ah. Now we're getting somewhere. I believe that Charles Garrity, whom I mentioned before, would work on at least the heating system.
    Could we, perhaps, be allowed to know what sort of work needs to be done? What the problems are? We might just be able to be more helpful...
