No pressure
smoore11
Member Posts: 1
I have a Williamson steam boiler and it won't build pressure. It worked well until 2 weeks ago then I lost pressure. Not sure if the cast is broken though I see no signs. No sign of cracked pipes. Replaced pigtail and pressuretrol which is set at 1/2 pound. I've read about vacuum problems but am at a loss
A residential steam boiler and heating system shouldn't build pressure. If all is working as it should be, and sized correctly, the pressure should never go above half a pound. Which is not to say that most systems have oversized boilers, and thus the pressure does.
In this instance, though, if it was building pressure and shutting off on the pressure control before, and isn't now, I might be suspicious of a leak.
The most reliable sign of a leak is water use: a gallon or two per month is reasonable. A gallon or so a week is a small leak -- and anything over that is grounds for serous further investigation. If the leak is steam into the firebox -- a frequent type -- you won't see it inside. You might see it outside, as wonderful clouds of steam from the chimney. Another common source is a wet return pipe -- a pipe below the water line of the boiler. In some basements, some of these are underground -- and the leak may not show.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England3 -
What @EBEBRATT-Ed saidEBEBRATT-Ed said:What @Jamie Hall said
What gauge are you looking at that shows no pressure?
The original 30 PSI is almost worthless.
Are you having trouble heating the house?0 -
Agree with Ed! AGAIN!EBEBRATT-Ed said:@JUGHNE
You were supposed to agree with us above LOL It doesn't happen very often LOL
Fine Then!.....I agree with everybody above.....
But now the OP is scared away and we will never know the outcome.
- 169 Indoor-Air Quality
- 50 Industry Classes
