Soaked oil rag safety disposal
Good grief. They shouldn't have left them behind. Sloppy. That said the only safe way to handle them is in a sealed, airtight, metal container -- or completely out in the open, outside any building, unfolded or scrunched up -- laid out.Br. Jamie, osb
Did they just leave them laying on the floor or put them into your waste can?0
You can toss in trash. It is not considered an oil spill.0
@joe V, The issue is not so much environmental, but the potential for spontaneous combustion. The advice @Jamie Hall posted addresses this concern.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
It is, unless the rag is perfectly clean and and not cotton or wool. But why take chances? A nice fire in the basement can ruin your whole day...ChrisJ said:I've heard of linseed oil spontaneously igniting, but never Diesel fuel.
That's a new one on me.
I mean I could be wrong, but I don't believe it's possible.Br. Jamie, osb
> @Danny Scully said:
> Flash point of #2 oil is between 126-204...
>>Atomized. Used to toss my cigarette buts in my waste oil all the time.
Put the rags in a bag and leave it at the door of the service company.3 -
Being safe is always wise, personally I'd throw oil soaked rags in a can out side for the stink alone.Jamie Hall said:
That said, there's also a point of going too far for no reason. For example, we don't store bread in a lead lined container as we would Plutonium.
Also keep in mind, most including OSHA do not consider Diesel or #2 heating oil to be flammable.
As @Danny Scully said, flash point of 126-204F.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
what @Jamie Hall said is correct. I would put them outside the house & let them dry completely in the sun. After that toss in the trash.
Same thing as rags which have kerosene, turpentine, paint thinner or stain.
Will any of those self combust? Probably not but don't take a chance.
Better to be safe than sorry
I would certainly call them and complain, sloppy and LAZY. no wonder people switch to gas.1 -
on the hazard/safety diamond, diesel has a flammability rating of 2.
environmentally, diesel will breakdown in a landfill. Two rags doesnt qualify you as a waste oil generator.0 -
No one said it did. I'm just being cautious...Joe V said:on the hazard/safety diamond, diesel has a flammability rating of 2.
environmentally, diesel will breakdown in a landfill. Two rags doesnt qualify you as a waste oil generator.Br. Jamie, osb
Once had a job with a really old burner that had sagged a little and the burner blast tube was pitched back toward the burner instead of down toward the fire box.
The cutoff in the old Webster Pump failed and oil dripped into the blast tube and ignited on the hot tube after the burner shut off.
The fire follow the blast tube and dripped out on the floor still burning. They had stored paper bags with empty soda cans near the boiler, the bags caught fire and only the soda cans were left.
Lucky for them the Firomatic valve melted and shut the oil off.
It still could have burned down the house. They were lucky old 1860s house would have gone up quick.
I don't give a dam about flash points or what class of flammability fuel oil has.
use common sense.
What if those rags were under the burner and the same situation happened?
Sometimes it's not one hazard. Sometimes several things go wrong at the same time and the results are horrific.
What would those who said it's not hazardous say if the place burned down?
The book says it's ok???
@EBEBRATT-Ed Have you checked your PM's lately?
IIRC and the reports are correct a movie theater a few miles from here had spontaneous combustion of cleaning rags from the popcorn oil. Fire in the lobby/concession area was enough to total the building with smoke damage.
Also another interesting event was an explosion of a underground diesel fuel storage tank, (5-10,000 gallon) lighting hit the ground and the tank exploded making quite a crater. As the C-store was closed, I was told the tank was empty and would have only fumes which were the source of the explosion. FWIW0 -
Yes, popcorn oil I can see.JUGHNE said:IIRC and the reports are correct a movie theater a few miles from here had spontaneous combustion of cleaning rags from the popcorn oil. Fire in the lobby/concession area was enough to total the building with smoke damage.
A petroleum product I cannot.
From another site.
"It's oxidation that creates the potential for spontaneous combustion. Petroleum products like motor oil and gasoline, while flammable, do not undergo oxidation. Also, the tendency of oil to spontaneously combust is related to its iodine number — if it's 130 or greater, the potential is there."
This of course doesn't mean something containing rags soaked in gasoline or Diesel cannot be ignited. That should be obvious. But they won't just burst into flames on their own like Linseed oil has been known to do. I was always warned about this with Linseed oil.
That's my understanding.
I'm by no means an expert, I know only what word of mouth and a quick Google search provided me.
@Jamie Hall Seems to feel the material of the rag may come into play. I have no idea, that's well above my knowledge. I just couldn't find anything to suggest it was true. Doesn't mean he's wrong either.
Like @EBEBRATT-Ed said, use common sense. Of course the rags should not be left on the floor. Like I said, even if they weren't dangerous, they stink!
No one should ever store combustible or flammable items near a boiler regardless. That too, should be common sense.
Back when I was a boy, we had a situation where a wool navy watchcap that was wet from melted snow and stuffed into a jacket pocket spontaneously combust.
I wouldn't have thought that could happen, but it did. Fortunately we smelled the smoke and found the source before it burst into flames.
We were lucky that day with no loss other than the charred watchcap and jacket.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
When I was just starting out as a mechanic, I worked with an old salt that would regularly cut rusty steel fuel lines full of gasoline with an abrasive cutoff wheel chucked into his high-speed die grinder, sparks flying everywhere. When I asked him about the intelligence of doing so, he told me that "liquid gasoline isn't all that dangerous...it's the vapors...so cut quick." He also did everything (fuel filters, tanks, pumps, injectors) with a lit cigarette hanging out of his mouth. Ah, Rick, I hope you're still alive...but if you're not I can guess why.
At work we have a 55 gal drum that old spent oil sorbent goes into...floor dry, absorbent pads, sawdust, anything soaked with oil. Then the local waste oil company picks it up when full and incinerates the contents.
Side note: drained oil filters are still allowed to go in the municipal garbage collection around here. Always thought that was odd.Ford Master Technician, "Tinkerer of Terror"
Police & Fire Equipment Lead Mechanic, NW WI
Lover of Old Homes & Gravity Hot Water Systems0 -
As for the oily rags, I would dry them and throw the away. If you want to make a point, take them to the oil companies office and set them on the front desk.
If you have seen the movie Spinal Tap you would know how common spontaneous combustion is. Particularly with drummers..."If you can't explain it simply, you don't understand it well enough"
Albert Einstein2 -
So wait,Zman said:As for the oily rags, I would dry them and throw the away. If you want to make a point, take them to the oil companies office and set them on the front desk.
I should trust a movie over what chemists say now?
Or trust the internet for info?
Always good to be careful with oily things, plastic and heat. I have seen some scary things catch fire.All it would take would be another product on the rag from another job and poof....
Just as long as the nobody is arguing with the Rock and Roll drummers combusting. Those guys have unique chemical makeup.
Albert Einstein0 -
The chemical composition of materials can change also.
Some years ago I was pounding staples on the sides of floor joists in an old basement when the light bulb popped and as the burning filament flamed up the light socket burst into flames. It was the typical surface mount "barn light" fixture as I refer to them. These are brown surface mount wiring devices that double as junction boxes for feed thru etc....switches, outlets, light sockets and J-boxes.
They are made from Bakelite or some Phenolic type material.
My best guess is that having a 300 watt bulb in it for 50 years caused the plastic to carbonize back to flammable carbon.
This can happen to wood inside walls behind plaster/lath that is near a wood burning stove pipe........as a fireman helped carry the stove out of the house late one night.
The wood gets baked into charcoal lowering its ignition point.
How it baked the studs and not the lath I don't know.1 -
@ChrisJ said:
...From another site.
What if Oxygen is the problem with us?
I believe that oxygen is Killing all of us... It just takes between 70 to 100 years to happen.
More specifically raw linseed oil. Boiled linseed oil won't oxidize in an exothermic reaction.
When I was a kid the oil burner tech would ask my mom for some old newspapers and wrap up the old filters and sometimes the contents of their soot vac in it and throw it in the trash can outside.0 -
Hmm, not sure about the bakelite pony cleat light socket itself burning. I could see it shorting with the broken filament swinging around and temporarily drawing more current and a bad connection arcing. Sometimes they put wood in bakelite as a filler although i wouldn't think they would do that for electrical products.
Maybe the socket was some other early plastic like acetate or nitrocellulose.0 -
I distinctly remember the socket itself burning. The broken bulb may have tripped the CB. Once the bulb is broken the filament quickly burns up. My head has broken many bulbs with this result.
I recall having to beat the fire out with my hat. FWIW0 -
I personally just throw them in the washer and wash them with my work clothes then you have clean rags and clean clothes0
- 15.8K Strictly Steam
