Sawzall Sunday
SomeTradesJack
Member Posts: 32
"The right tool for the right job," my dad always said. Instant BTU increase with removal of plywood boxes. All manner of radiators in this old place.
Before:
After, with high-tech humidifier:
Before:
After (obviously a replacement, but why piped in this manner?):
Before:
After--custom support revealed:
Before:
Before:
Before:
You'll want to find a proper radiator to replace that fin-tube convector element.All Steamed Up, Inc.
Consulting1 -
Be a good time to scoot the outlet over before installing a new radiator (or cabinet).EdTheHeaterMan said:The last one needs a cabinet to get the full capacity.
Removing those covers is a matter of taste. Someone sure went to a lot of trouble to make them. The humidifier is neat ( unless it leaks).0
I have a receptacle that is half behind an original door casing (a closet was added during the original construction but after electrical rough in). Love the wallpaper too. I suppose the carpet and padding would be good insulation for heat and noise - if it was still there. Is that an old radiator humidifier that they just built in to the radiator cover?0
Actually, it slides in between the fins of the radiator itself. There are several around the old place. Out here in the West, any moisture is good.ChicagoCooperator said:Is that an old radiator humidifier that they just built in to the radiator cover?
I love how they covered half an outlet. Didn't need that anyways. lol
And if it makes you feel any better my house has wallpaper on the ceilings... That has been painted over too.0 -
Sometimes plain paper was used to hold cracking plaster together. Otherwise anyone that paints over wallpaper should be shot.
Good wool carpet was far superior to synthetic carpet. Maybe not so much for the rubber pad.0 -
If it’s fed by armor cable I’d put a GFCI breaker in the panel for that branch (or a GFCI outlet if no breaker available) and then switch the outlets to three prong. Can’t remember the NEC section that allows it but it’s there.SomeTradesJack said:Yep, electrical is on the list. Note: no ground.
if you’ve got K&T it’s probably time for rewire.0
- 167 Indoor-Air Quality
