Water Filter install
Is it me or do others have issues with fittings into whole house water filters. I’ve installed two of them in my two sons homes. I had leaks on both of them on the threaded fittings. I use Teflon tape as directed, trying not to overtighten but still had small drips. I can sweat fittings all day but threaded fittings give me fits. Is it the quality of the threads? I always check take nipple or other fitting for good threads. The filter housings are some type of poly or non metallic composite. I have not found any that have a metallic insert already installed. I do add Teflon paste also. Any advice is appreciated. Thanks. Mike
Plastic or Metal?0
The housing and female threads are some type of plastic or poly. You have to be real careful to not us too much tape or it is hard to start the threads with the male fitting without cross threading. I could not find a whole house filter with a metal female insert formed into the housing.0
On the housings with the plastic threads, I use a combination of pipe dope and tape. I use Megaloc dope and Monster tape, and will wind like five wraps of tape on the threads. Also, if I can, I will put a union on so if it doesn't seal up, I can re-do it. I hate plastic female threads,so if you can find them, get the ones with stainless inserts. But for some reason, they are very difficult to find.
Rick1 -
Rick, That is exactly what I use. Maybe didn’t use enough turns of tape. I did not put in a union like I usually do, so when I take it apart I will. I generally use the bronze unions because I have had issues with the copper ones. This was a add a whole house filter before a new softener so I used a Sharkbite fitting to the existing copper. Not a problem undoing it right now. We have more upgrades planned in the future so that’s why I used the push fitting. Thanks. Mike0
Plastic fittings NO Teflon Tape!
regular pipe dope. Hand tight 3/4 to 1 full turn is usually all that's needed.0 -
Stay back a thread or 2 when you wrap the tape so you can start it properly. Could always break out the single strand wicking too.0
@MikeG As @mattmia2 says above.
Also, Wrap the [white] Teflon tape clockwise (I use six Wraps "Tightly") around the threads leaving the first two threads without Teflon tape.
Then I screw the threads of the entire fitting into the head of the filter head housing. And I mean all the way up to the flats of the male adapter.
Most often the head will expand while tightening and not leak and not crack. I must have done a few hundred this way with little to no leaks.
And be very careful not to cross-thread when starting this fit. It's a reason why, as mentioned before, to leave the first two threads with no Teflon on them. It makes it so much easier to start the threads.0 -
Thanks. That makes sense. I’ll give that a try with the tape. It is easy to get it cross threaded with tape all the way on the end. Mike0
Often, we'll start with single strand ball / string wicking for this type of connection - wrapped tightly clockwise with several layers of quality Teflon tape on top of it.....0
I have had the same issue on multiple filter housings. My current recipe for success is: 3 wraps of Blue Monster tape, a skim of Leak Lock thread compound, hand tight + 1/2 turn.
I just installed a "big blue" sediment filter in my own home yesterday due to some sediment chewing up the seals in my Fleck 2510 back-washing filter.0 -
You're not alone, Mike! Leaky threaded fittings on whole-house filters are a common complaint. Here are some thoughts:
- Quality matters: Check for burrs or imperfections on the threads, even if they look good. Invest in high-quality fittings if possible.
- Teflon trick: Wrap the tape in the direction of tightening (clockwise) and only use enough to fill the gaps, not smother the threads.
- Seal the deal: Try using both Teflon tape and paste for extra security. Some prefer hemp over tape for plastic threads.
- Torque it right: Overtightening can crack plastic housings. Use a wrench and tighten snugly, but not gorilla-style.
- Check the taper: Make sure the threads are tapered correctly for a tight seal.
- Double-check direction: Double-check the water flow direction and ensure fittings are facing the right way.
- Consider alternatives: Some filters offer push-fit or compression connections, which might be easier for you.
0 - Quality matters: Check for burrs or imperfections on the threads, even if they look good. Invest in high-quality fittings if possible.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 108 Geothermal
- 983 Plumbing
- 389 Solar
