Taco circulatory pump question - not spinning due to not being oiled?
rkbentley93
Member Posts: 4
in Oil Heating
Recently, I had to have the local oil company repair guy come over due to my taco circulatory pump wasn't spinning and thus not sending hot water into the vents. The furnace was working fine but the pump wasn't spinning. It didn't spin and according to him it burned out the fuse in the Taco SR501 Single Zone relay. He had replaced the fuse and spritz some 2-in-1 or 3-in-1 on the pump.
I ordered some 3-in-1 to be on the safe side and a few days later the furnace came on, the pump came on and I checked and it wasn't spinning so I spritzed it and it started spinning, it was also spinning all the 3-in-1 all over the floor.
Some backstory: I inherited the house with the furnace and the circulatory pump 10 years ago so I don't know how old they are. The furnace probably needs to be straight up replaced. The relay has been replaced within the last 5 years.
I haven't had this problem before so I dunno if the pump is dying or piece of it died and it's just limping along. Or it's because I skipped the yearly cleaning last year due to covid.
I saw the instructions about 3 cups of oil but didn't even know where to put that since well, as you can see from the attached 2nd picture, 3-in-1 all over the floor now.
I've attached pictures of what the pump looks like I can't find a serial # on it.
Any ideas? Thanks!
Any ideas? Thanks!
Can you circle these cups? I've added another photo of the entire pump can you circle where those cups are? I haven't a clue.
try this
known to beat dead horses0 -
@rkbentley93
Since the service tech just oiled it more oil isn't the fix.
It could be the pump motor or it could be the bearing assembly.
If I were you I would replace the pump. That's an old timer
If it's making noise it is likely the bearing assembly. Also put your hand on the motor and see how hot it is1 -
@neilc - thanks! Big help!
@ebebratt-ed - thanks. It's not making any noise. And I don't know if he oiled it with electric oil or put some 3-in-1 in there.0 -
guys,
that motor label says No(#) 40 or 50 oil,
they don't mean 40 or 50 weight as we know it today, do they(Taco) ?
Why wouldn't the service tech suggest replacing the pump? just curious0
@billyo - He did mention replacing the entire furnace which is on my wish list but he didn't make mention of the replacing the pump.
Time to contact the oil company and get an estimate...
Yes indeed they do. Single weight SAE 40 or 50 oil. That's exactly what they do mean, and what it needs. The 3 in 1 will get it spinning -- briefly. But it won't stay put.neilc said:guys,
they don't mean 40 or 50 weight as we know it today, do they(Taco) ?Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England1
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
