Quality boiler drain valve
dbsoccer
Member Posts: 43
When the weather warms up a bit, I will be faced with repairing or replacing my boiler's drain valve. I am looking for a recommendation for a brand/model that will be reliable.
Any input would be much appreciated.
Thanks Bob.0
I like this type a lot. You may need a nipple depending on your application. I even used them the last time i needed a supply for a washer.
https://www.supplyhouse.com/Webstone-40313W-3-4-Female-x-Hose-Full-Port-Ball-Valve-Lead-Free0
