Leak
oldburner
Member Posts: 4
Hot side coming out of boiler
hot water ,,,
has a leak
can I use a shark bite fitting
there instead of sweating
in copper with out any problems ?
thx
hot water ,,,
has a leak
thx
Pictures?0
Hold your new fitting next to the old one, not an exact line up.
You need to have an offset on the vertical pipe.
The Sharkbite will only accept a bare pipe and not the end that still has the fitting soldered on it.
What are the temp limitations of the Sharkbite fittings?
You have to drain the boiler in any case, unsolder or cut and add length and offset.
So soldering would be the easiest route, IMO.0 -
I don't think you need to drain the boiler, looks like a tankless heater connection.
You might need a short piece of copper and a shark bite coupling.
I never used shark bite, I would solder it0 -
- 120 Geothermal
