Infrared thermometer
rgar98
rgar98 Member Posts: 66
Anyone use an infrared thermometer to measure flue temperatures? Are they helpful? Which brand?
    pecmsg Member Posts: 6,740
    For general readings............
    maybe at best.
    Read the instructions, type of material, distance from surface, color all effect the readings.
  • SlamDunk
    SlamDunk Member Posts: 1,789
    A quality thermometer gage in the flue gas stream is best.
  • Canucker
    Canucker Member Posts: 723
    I use them to measure delta t, not accurate enough for anything other than general temperature readings, imo
    You can have it good, fast or cheap. Pick two
    dennis53
