Steam pressure too low?
bwroga
Member Posts: 44
After reading about it in "We Got Steam Heat", I checked the pressuretrol to make sure it wasn't set to high. It was set to 0.5 with about a 1.0 differential. It was kind of hard to tell because I wasn't sure exactly which direction the number on the differential dial was supposed to face.
I then turned the thermostat from 65 to 70 and waited for it to get to about 68 before checking the pressure gauge on the boiler and it was at 0, not anywhere close to even 0.5. Is this something I need to be concerned about? We have no complaints with the heating ability of the system.
Presumably you were looking at the required 0 to 30 psi gauge? If so, you won't see anything on it. If the system is heating nicely and not cycling, it's probably running at no more than a few ounces -- that's ounces -- of pressure -- until all the radiators are hot and all the vents close. Which is exactly what you want.Br. Jamie, osb
The job of the pressurtrol is this: “Oh crap why the heck is my pressure this high, turn the boiler off NOW!”
You don’t want pressure, it isn’t necessary nor desired for proper function of the heating system.
Be happy you aren’t getting pressure it’s a good thing.2 -
That's great news. Thank you! I feel so lucky that the system is running so nicely. I had only lived with steam one time before buying this house, and back then, it wasn't my responsiblity!0
I installed my 3psi gauge today.It maxed out at 0.15 psi (2.4 ounces) recovering from a 2 degree setback. Amazing how it’s possible to heat the house (and 18 radiators) with so little pressure.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 959 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
